Cannot Find Thermo-Physical Properties Of Calcium Chloride Cacl2
cacl2 properties
10 replies to this topic
#1 IonCube
IonCube
  • 62 posts
Posted 14 April 2019 - 03:27 AM
This platform has been immensely helpful to me because I am in chlor-alkali sector. As such I always need experimented properties e.g this post is great about NaOH propeties
https://www.cheresou...ies/#entry46349
^ I effectively had used these to prepare HYSYS *.hyp properties file
Now I have searched the internet (& I am good at it) but cannot find CaCl2 gravity / w.t% / isotherm tables akin to that of NaOH. For designing CaCl2 rising evaporators specific heats at various w.t% is essential. So do please help
Secondly VMGSIM has a compound name CaCl2Brine which is classified as Oils? Plus its properties (density Cp) are very very different to that of CaCl2 aqueous solutions. What is this oil?
  • Attached File  PFD.jpeg   64.34KB   1 downloads
Edited by IonCube, 14 April 2019 - 03:30 AM.
  • 6,715 posts
Posted 14 April 2019 - 04:43 AM
hi,
Let you try your favorite search engine , as I did , key words : Thermophysical properties cacl2.
A lot of stuff , of course you will need to dig !
I will check my personal resources later.
#3 breizh
  • 6,715 posts
Posted 14 April 2019 - 05:37 AM
hi ,
To start with :
https://www.engineer...ter-d_1186.html
http://www.phasediag...um_chloride.htm
https://www.amcmud.c...ables-Oct17.pdf
https://www.oxy.com/...e/173-01791.pdf
A few technologies about concentrarion
http://www.chemprosy...ompressed11.pdf
Good luck.
Edited by breizh, 14 April 2019 - 09:28 PM.
#4 IonCube
IonCube
  • 62 posts
Posted 14 April 2019 - 06:25 AM
Thanks for replying. However I think I may haven not described my problem fully. In an evaporation plant lets suppose I take out a sample of CaCl2 aq. from 2nd effect @95C. Using hydrometer / thermometer I can have both S.G or density / Temperature
Now I need a table to judge w.t% of aforementioned sample using two measure inputs
If I have access only to cooling water @33C I cannot cool the sample to 25C; temperature upon which most graphs/properties are published!
#5 breizh
  • 6,715 posts
Posted 14 April 2019 - 06:38 AM
To me the best way is to use in line mass flowmeter which generates density and temperature at the same time to get access to the concentration .
Hope this is helping you .
#6 PingPong
PingPong
  • 1,466 posts
Posted 14 April 2019 - 10:48 AM
See Table 1 and formula (4) , (6) and (7) in:
Attached File  MATHEMATICAL MODELLING OF CaCl2 AQUEOUS SOLUTIONS THERMOPHYSICAL PROPERTIES.pdf   659.85KB   16 downloads
Perry also contains a useful table of density (g/cm3) as a function of wt% and temperature:
Attached File  Calcium Chloride Solution Density (Perry 8th Ed).jpg   95.1KB   7 downloads
Edited by PingPong, 14 April 2019 - 03:11 PM.
#7 PaoloPemi
PaoloPemi
  • 550 posts
Posted 15 April 2019 - 05:01 AM
with reference to your post #1, which type of problem do you wish to solve ? Thermophysical properties ?, phase equilibria ? phase equilibria + heat balance ? For a evaporator probably you wish to solve the last,
in my opinion, for single units, tools as Excel can be very useful, see also the example provided by PingPong
#8 breizh
  • 6,715 posts
Posted 15 April 2019 - 06:46 AM
http://www.tetrachem...s/Solutions.aqf
https://www.sepwin.c...lcium-chloride/
hi ,
Additional input , including estimation within the range (% Cacl2 [ 2-48%] ; Temp [-20C - 80 C]
outside the limits ?
Edited by breizh, 17 April 2019 - 09:43 PM.
#9 IonCube
IonCube
  • 62 posts
Posted 17 April 2019 - 06:00 AM
attachicon.gifMATHEMATICAL MODELLING OF CaCl2 AQUEOUS SOLUTIONS THERMOPHYSICAL PROPERTIES.pdf
Excellent reply & thanks. In this paper there is an statistical eq. to model that relates (density, T & w.t%) of CaCl2 aq. solutions. I have setup a fairly simple spreadsheet with goal seek to get my answers without the need to refer tables & graphs. But this isn't working. Please check the attached excel file & a screenshot
In an evaporator there are many recuperator (S&T xchangers) as well. For those to design I need multiple variables which includes density as well. I have asked the researcher (whose paper is refereed) above for further details.
Solution w.t% is required from operational point of view. You see in operations your operator can give you x2 measure variables i.e T & S.G ...I need to calculate w.t% afterwards
#10 breizh
  • 6,715 posts
Posted 17 April 2019 - 06:51 AM
http://www.tetrachem...lators_Menu.aqf
hi,
Simple calculator concentration vs  density only .
#11 IonCube
IonCube
  • 62 posts
Posted 17 April 2019 - 09:31 AM
It will not do, because the calculators have no temperature variable consideration! Plus the data you provided earlier (thanks for it) doesnt extent to 60w.t% < my final effect outlet
Now in operations if for instance you don't have a chilled water readily available you cannot cool the sample to 25C (at this data is mostly available) ...Cooling water temps here in summer are 30-32C. Lab analysis I avoid :)
