Good day,
For our plant design requirement, we are employing a decanter centrifuge for our process. The stream at inlet of the decanter only has around 1-2 wt% of solid. Is there a way to know how much of the liquid would adhere to the solid? Or is there any general heuristics on the value of the adhered solution? I've been searching so much about this but I just can't find any information on it.
For reference, the liquid is glycerol-methanol-water (with little separate oleic acid phase) mixture and the solid is monopotassium phosphate.
Thanks for taking the time to read my inquiry. Any help is greatly appreciated.d
Decanter Centrifuge Adhered Solution To Solid
Posted 25 May 2019 - 12:50 AM
Posted 25 May 2019 - 01:01 AM
Additionally, i need to separate all of the solids present. In that case, it's not possible to separate it without any liquid adhering to it. That's why i need to know how much of the liquid will go with the solids. Thank you!
Posted 25 May 2019 - 01:28 AM
To me only pilot test with product will give you the answer . It will depend on the shape of the solid, the temperature, the viscosity , the rotation speed,etc .
You may contact companies like Andritz, Robatel ,....
http://www.ohiowea.org/docs/Smith.pdf
good luck
Edited by breizh, 25 May 2019 - 01:42 AM.
Posted 25 May 2019 - 01:44 AM
good luck
Thanks for the reply. It's true that only a pilot test can really determine the true amount. I just hoped to find any general information on the amount of adhered solution to the solids, whatever the system is. (Although I know it really varies from case to case)
Posted 25 May 2019 - 02:42 AM
If the objective is the solids and you need them dry, then you can consider a press. Specifically, dewatering presses. Centrifuge is for when the target is the liquid. Presses are for when the target is the solids. Although, generally both separate liquid from the solid, the objective would change the preferred equipment type. Although a centrifuge can still be used if there are other consideration factors such as flow rate and hydrophilicity etc...
If you need them even drier, then you need a second drying step. First step should take you about 20 to 30% dryness. Second step would take you to much higher such as 95%. Bone dry will need a third step although this is only needed if >>99% is required.
Edited by thorium90, 25 May 2019 - 02:42 AM.
Posted 25 May 2019 - 05:41 AM
Thanks for the response
I actually need the liquid phase to not have any solid present anymore. The dryness of the solid doesn't matter in our case. Is this possible to achieve (considering that the feed only have low solid content which is about 1-2 wt%)? and how much of the liquid will go with the solid (even just a rough estimate of it)? Thanks again.
Edited by ChE student17, 25 May 2019 - 05:42 AM.
Posted 25 May 2019 - 05:51 AM
If the objective is for getting a liquid without any solids, then you can try filtration. Membrane filtration is a common method. Ceramic membrane ultrafiltration is a possible option.
Posted 26 May 2019 - 05:21 AM
hi ,
For you and others
* a lot of technical information about filtration in the link attached :
http://bhs-filtratio...cal-articles/#1
** a general comment about decantor centrifuge , you need to add flocculant , is this compatible with your process ?
With solid concentration so low you need a tickner prior to centrifugation or hydrocyclone .
good luck
Edited by breizh, 26 May 2019 - 05:21 AM.
Optimal Settings And Clogging Prevention For Gnlw224E Decanter CentrifStarted by Guest_Lev1231_* , 02 Feb 2025 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Any Solution For Unstable Run By Hysys?Started by Guest_AnbIran_* , 29 Jun 2024 |
![]() Solid Naoh Dissolving In WaterStarted by Guest_lak1r_* , 10 Apr 2023 |
Recycling Of Working Solution In The Anthraquinone ProcessStarted by Guest_Has2riasat_* , 01 Feb 2024 |
