How Do You Convert Ppmv To Ppmmol And Vice Versa
#1 chemproc
chemproc
  • Store Customers
  • 67 posts
Posted 03 June 2019 - 08:40 AM
How do you convert ppmv to ppmmol and vice versa. Or are they the same? If so why?
Thanks,
#2 PhilippM
PhilippM
  • 98 posts
Posted 03 June 2019 - 04:55 PM
I have never actually seen those units used anywhere (and would in fact try to avoid any "parts-per" units), but if you are talking about an ideal gas: At the same temperature and pressure, every mole of every gas has exactly the same volume, so ppmv and ppmmol should be the same
#3 Chemitofreak
Chemitofreak
  • 292 posts
Posted 04 June 2019 - 01:36 AM
It is quite simple. PPM or Parts Per Million is one part of a particular component in million parts of the total mixture.
1) ppmw = parts per million by weight = 1 milligrams per kg
2) ppmv = parts per million by volume = 1 milliliter per m3
3) ppmmoles = parts per million by moles = 1 milli-mole per kg-mole
you know the composition, mass of the mixture and temperature-pressure, you can inter convert  into any of the units
For water i.e. when density is 1000 kg/m3....1ppm = 1 mg/liter
For ideal gas ppmv = ppm mole as vol% = mol%
Revert in case of any query
Edited by Chemitofreak, 04 June 2019 - 01:39 AM.
#4 oilpmp
oilpmp
  • 10 posts
Posted 06 June 2019 - 05:28 PM
i use the following formula  for gases:
ppm w/w =(ppm v/v of component X in gas mixture Y) * (Mol. weight of component X)/ (Mol. weight of gas Y)
w: stands for weight ; v:stands for volume
For example X can be H2S compound and Y a methane gas mixture containing that H2S compound.
#5 nivedita12
nivedita12
  • 46 posts
Posted 18 June 2019 - 01:37 PM
Please see this formula It is very good resource
https://neutrium.net...on-conversions/
