Hi All,
I work in a 300 m3/hr ion exchange demin plant which uses HCl 36% and NaOH 47% for resin regeneration, both of these chemicals are stored in 15m3 storage tanks. These are atmospheric thermoplastic tanks which are more or less identical, the main difference being that the HCl tank is vented to a fume scrubber while the caustc tank is vented to atmosphere. Both are topped up via road tanker, HCl is taken off by delivery pump and caustic is delivered by compressed air at approx 2 bar.
One issue we have with the caustic tank is that now and again we get some liquid escaping the vent which then crystallizes on the roof and down the size of the tank. It's definitely not overfilling as we have a high level sensor to shut the delivery valve at 95% and an overflow pipe just above this. It's not a frequent occurence so I've never actually seen at what stage of the delivery this happens but I suspect it's at the end when the barrel is depressuarizing through the tank and out the vent?
Last year we tried to solve this by extending the vent using a 3 meter spool piece. This didn't solve the problem and instead just made it more hazardous, raining droplets over a wider area. Few pictures below...
caustic1.jpg 283.67KB
11 downloads
caustic2.jpg 184.26KB
13 downloads
caustic3.jpg 146.94KB
12 downloads
The tank has a 2" delivery line entering the top on the tank (splash filling), 4" overflow pipe and 6" vent with cowl.
Looking for some advice on how best to avoid this or at least contain the carryover?
One thought is to make the vent the same as the overflow, having it come down close to ground level where I could have a dustbin and rags to catch any droplets, not solving the problem but at least containing it and not having to decontaminate the tank and bund every year. Others have suggested baffles in the vent or a coarse mesh to knock out any carryover, but to me this just risks blocking the vent and potentially causing the tank to overpressuarize during delivery.
Edited by -G-, 04 June 2019 - 08:08 AM.
