Let's say we want to dilute a 90 w% H2SO4 solution to a 60 w% solution. Regarding the heat released, does it matter if we do it with the help of water or with e.g. a 10 w% H2SO4 solution? If yes, in which case will more heat be released?
Posted 02 July 2019 - 07:15 AM
Posted 02 July 2019 - 07:31 AM
Let you study the pamphlets attached .
Hope it helps you and others
Edited by breizh, 02 July 2019 - 07:33 AM.
Posted 02 July 2019 - 04:33 PM
Thank you!
So the heat calculation methods let me conclude that it doesn't matter if we dilute with water or with a diluted H2SO4 solution, but it would be nice to hear a confirmation of my conclusion.
Posted 02 July 2019 - 08:19 PM
hi ,
If you perform a mass balance you should be able to evaluate how much Sulfuric will be used for both cases . To me the diluted acid will save about 5% of the total quantity you need . All depends if you have sufficient enough diluted acid available .
Recycling diluted acid is a bit more challenging and need more equipment to match the mass balance.
In other words , no much difference in term of heat released .
Posted 03 July 2019 - 05:55 AM
So the heat calculation methods let me conclude that it doesn't matter if we dilute with water or with a diluted H2SO4 solutionThen you must have done it not quite accurate.
Assuming all the starting fluids have the same temperature whether diluting with water or diluting with 10w%, diluting with water will result in a higher product temperature than diluting with 10w% as more heat will be released.
The difference is not big, but in a calculation clearly visible and in actual practice clearly measurable.
Posted 03 July 2019 - 07:00 AM
In order to get a 60 w% solution, we need to add more 10 w% solution than water, so it's clear that in case of water the product temperature will probably be higher, because the amount of product solution is smaller which absorbs the released heat. However my question is not about the product temperature, but the heat released during the dilution process.
Posted 03 July 2019 - 09:50 AM
That is not correct.
Amount of product solution is not smaller, because it is the product solution you want to make.
If you want to obtain say 100 kg 60 w% product then you need to select the amount of 90w% and the amount of water or 10w% such that you end up with 100 kg 60 w% product.
However my question is not about the product temperature, but the heat released during the dilution process.That is the same thing: the warmer the resulting 60w% product the more heat must be released during the mixing.
You can read both from a sulfuric acid - water enthalpy diagram like in the links provided by breizh, or many other sources on internet or in textbooks.
It seems that you did not really try to calculate the effect of the mixing.
Edited by PingPong, 03 July 2019 - 09:55 AM.
Posted 03 July 2019 - 11:48 AM
Ok, there are some misunderstandings...
In order to get a 60 w% solution, we need to add more 10 w% solution than water, so it's clear that in case of water the product temperature will probably be higher, because the amount of product solution is smaller which absorbs the released heat.That is not correct.
However my question is not about the product temperature, but the heat released during the dilution process.That is the same thing: the warmer the resulting 60w% product the more heat must be released during the mixing.You can read both from a sulfuric acid - water enthalpy diagram like in the links provided by breizh, or many other sources on internet or in textbooks.
By "the heat released" I mean e.g. how many Joules will be produced.
If during mixing Q [J] heat is produced, then the product's temperature will change according to Q = c•m•ΔT, where c is the heat capacity. So the product's temperature depends on its mass (m), but I only want to know if the Q [J] is the same in case of water and in the case of a 10 w% solution.
So if my conclusion (based on the diagram) is correct, then:
if we have a given amount of 90 w% H2SO4 solution, and we dilute it to a 60 w% solution, the same Q heat is produced, it doesn't matter if we use water, or a diluted H2SO4 solution. In the latter case we just have to add more diluting agent, (so the amount of the product will be bigger).
Edited by Sulfuricacid, 03 July 2019 - 11:56 AM.
Posted 03 July 2019 - 01:41 PM Best Answer
That is in general not correct.
Diluting a given amount of 90 w% acid with water to obtain a resulting amount of 60 w% will produce more heat than diluting it with 10w% acid.
For example:
100 lb of 90 w% acid at 70 oF plus 50 lb of water at 70 oF gives 150 lb of 60 w% acid at about 228 oF and -29 BTU/lb
100 lb of 90 w% acid at 70 oF plus 60 lb of 10 w% at 70 oF gives 160 lb of 60 w% acid at about 210 oF and -38 BTU/lb
Enthalpy of 60 w% acid at 70 oF is -115 BTU/lb
So heat released by diluting with water is 150 * (-29 - (-115)) = 12900 BTU
and heat released by diluting with 10 w% acid is 160 * (-38 - (-115)) = 12320 BTU
The difference is about 5 %, not big but still noticeable.
enthalpy diagram for sulfuric acid - water mixtures.jpg 356.02KB
29 downloads
Edited by PingPong, 03 July 2019 - 01:43 PM.
Posted 04 July 2019 - 05:07 AM
Well, this diagram also considers the temperature of the solution to be diluted and the diluting agent, which seems reasonable, so this might be the best way to calculate the released heat. Thank you!
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
![]() Moc Selection For 98.5% H2So4 Tank Sludge CleaningStarted by Guest_lakshmi.narayanan_* , 02 Jan 2024 |
Sulfuric Acid Production / Partial Pressure Of H2So4Started by Guest_Jon K_* , 22 Sep 2023 |
![]() Diluting Of Sulphuric Acid In Water Treatment Plant IndustriesStarted by Guest_YUMI_* , 15 Jan 2023 |
H2O2 Analyse In H2So4Started by Guest_Heisenbear_* , 14 Aug 2023 |
