Calculation Of Approach To Equilibrium Of Primary Reformer Catalyst
Started by muthukmaar, Jul 05 2019 08:36 AM
Posted 05 July 2019 - 08:36 AM
Please do suggest some books or article on the method to calculate the approach to equilibrium of a primary reformer catalyst
Posted 05 July 2019 - 08:12 PM
You may download the file in the below link and make a program in excel then vary you temperature (equilibrium) till you get similar methane slip as you are getting from your reformer outlet. Then take the difference between your actual temperature and equilibrium temperature.
https://www.google.c...9rk_qJIgI02ugHq
Posted 09 October 2023 - 11:24 PM
Hi Said,
Can you please provide the link because the file is not found anymore.
Thankyou
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
![]() Equilibrium Data For Nitric Acid And WaterStarted by Guest_ksagarzazu_* , 07 Oct 2024 |
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
