Burner Capacity Curves
fired heater process burner burner capacity curve heat release
#1 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 01 November 2019 - 09:53 AM
I calculated the total heat resulting from firing FG in a process heater by multiplying the total gas flow by the LHV of the gas
LHV = 949 Btu/SCF
Flow = 115,000 SCFH
Q1 = 109.14 MMBtu/hr
I also pulled out the capacity curve of the burners and at 11 psig gas pressure, the heat release per burner is 9 MMBtu/hr.
Q2 = 23 burners x 9MMBtu/hr = 207 MMBtu/hr
If I am not mistaken, capacity curves are for a specific gas composition and properties.
Why is there such a big difference between the two calculated values given that I am using the same gas properties? P.S: The FG Mol wt is 18 in the datasheet vs. actual Mol wt of 17.6 for the current FG used.
Sherif
  • 6,715 posts
Posted 01 November 2019 - 09:58 PM
https://books.google... burner&f=false
Hi Sherif,
Consider the link above , better If you have a chance let you find this book (reference below)
The John Zink Hamworthy Combustion Handbook: Volume 1 - Fundamentals
 Note : I found a value of HR # 4 MMBtu/h for methane at the # 11psig. Should not be very different from your gas specification ?  LHV # 910 BTU/scf .
Probably good to review your data .
My 2 cents
Edited by breizh, 03 November 2019 - 12:31 AM.
