Thermal Relief Valve Sizing
tsv relief valve thermal relief valve
#1 Perumal M
Perumal M
  • 18 posts
Posted 19 November 2019 - 10:56 AM
Hello everyone,
I am performing TSV sizing calculation to protect a 14'' pipeline.
Handling fluid is crude oil.
Solar radiation is 82 degC.
Anyone pls reply here, how to calculate Isothermal Compressibility Coefficient (χ)?
Peru.
Edited by Perumal M, 19 November 2019 - 10:56 AM.
  • 6,714 posts
Posted 20 November 2019 - 12:38 AM
You should find the answer using the search engine in this forum , Latexman if I remember well  published a post on this topic.
https://petrowiki.or...sibility_of_oil
Edited by breizh, 20 November 2019 - 01:35 AM.
#3 Perumal M
Perumal M
  • 18 posts
Posted 21 November 2019 - 03:43 AM
Thanks for your reply Breizh. It helped me lot.
Regrds,
Peru.
#4 walidd_23
walidd_23
  • 27 posts
Posted 28 November 2019 - 08:55 AM   Best Answer
Perumal,
you can calculate the pressure rise due solar radiation using simulation software as per following steps:
1- Creat stream of the crude oil under normal temp and pressure.
2- Copy same stream using solar radiation temperature.
3- Adjust the pressure of the new stream till you get same density of the original stream.
Walid
#5 latexman
  • 1,809 posts
Posted 02 December 2019 - 08:10 AM
breizh,
I think you may be referring to this one:
https://www.cheresou...pipeline-liquid/
#6 breizh
  • 6,714 posts
Posted 02 December 2019 - 07:24 PM
Hi Latexman,
Yes this is it.
Edited by breizh, 02 December 2019 - 07:24 PM.
#7 Chemitofreak
Chemitofreak
  • 292 posts
Posted 13 December 2019 - 01:49 AM
Hello everyone,
Peru.
In my company we do not size a thermal relief valve for protection against solar radiation. We simply specify a 'D' orifice.
Having said that one must be careful and also look at the fluid handle (like LPG) in the system.
Edited by Chemitofreak, 13 December 2019 - 01:54 AM.
