Cooling Tower
tower size no of bays
#1 274@P6
274@P6
  • 43 posts
Posted 31 December 2019 - 12:45 AM
Hi to all,
Could anyone share sample cooling tower design calculation sheet to find the cooling tower size approximately (Induced draft tower).
  • 6,715 posts
Posted 31 December 2019 - 05:18 AM
Use the search engine in this forum , I've posted numerous documents about Cooling tower .
Normally we provide the flowrate , the inlet temperature and expected outlet temperature  together with the weather condition ( min and max temperature of air , same for humidity ) for supplier to size the equipment.
Edited by breizh, 10 January 2020 - 01:53 AM.
#3 274@P6
274@P6
  • 43 posts
Posted 09 January 2020 - 07:29 AM
thank you for sharing.
how to calculate cooling tower liquid loading factor and Ka values? is there any chart available to find these values?
#4 breizh
  • 6,715 posts
Posted 09 January 2020 - 08:58 AM
Documents attached to support you work.
Note : Perry & Kern (process heat transfer ) are  also options
Edited by breizh, 10 January 2020 - 03:52 AM.
#5 breizh
  • 6,715 posts
Posted 09 January 2020 - 06:53 PM
To add to my previous reply , other documents .
#6 breizh
  • 6,715 posts
Posted 10 January 2020 - 01:16 AM
What you are looking for is known as Merkel coefficient /method.
Edited by breizh, 11 January 2020 - 01:09 AM.
