Impact Of Dry Trays On Distillation Tower
relfux dry trays
#1 NoobMi
NoobMi
  • 38 posts
Posted 10 January 2020 - 10:38 PM
Hi all,
I have a question on the operations of a minimum reflux ratio in distillation column.
Currently i have a 10 tray tower with inlet feed at the 5th tray.
1st question:
If i were to fully reduced the reflux ratio to 0, does it means that my effective distillation trays will only become 5 trays?
Also what will happen if dry trays were to occur? Will it have higher chances of fouling / mechanical failure, etc?
Or is there any minimum reflux ratio / wetting volume required in tray towers?
#2 Bobby Strain
Posted 11 January 2020 - 12:27 AM
Your query makes no sense at all. Why would you consider such an operation?
#3 PhilippM
PhilippM
  • 98 posts
Posted 11 January 2020 - 05:57 AM
The "dry trays" would simply not be involved in any separation process and are therefore completely useless. Instead you would just design the tower with 5 trays and have the feed at the top. Every tray needs both a vapor and liquid phase in order to work at all, and most process simulators will not converge otherwise, so you either need the feed at the top or a reflux. Maybe you should provide a sketch in order to explain what you want to achieve.
#4 breizh
  • 6,715 posts
Posted 12 January 2020 - 08:16 AM
Hi NoobMi ,
Like others I 've difficulty to understand your query . Are you a chemical engineer ?
Are your questions related to particular steps in your operation , let say start up for example ?
I've attached links where you can find information about Separation  processes , Rmin in distillation process , etc
http://www.separatio...om/Mainmenu.htm
https://escholarship...96n0xv#page-489
Edited by breizh, 12 January 2020 - 08:35 AM.
#5 horatorres
horatorres
  • 88 posts
Posted 03 April 2021 - 10:24 PM
It has no sense to do that...
Why you would like to operate wihtout reflux, if i undestand you¨???
horacio
