I am searching for Cp values for air( T=210 deg C, P=155 Kg/cm2). But to no avail. Can somebody help?.
Thanks in advance....
Cp Value For Air
Started by ASH25320, Oct 12 2006 11:14 AM
Posted 12 October 2006 - 11:14 AM
Posted 12 October 2006 - 04:07 PM
Hi there:
For the purpose of engineering calculations and considering that air behaves as the perfect gas -- having a constant specific heat value -- one can always use that the air cp value is 1.004 [kJ/kg*K].
Also, for air one can assume that the air gas constant value is 0.2867 [kJ/kg*K] and that the air specific heat ratio, kapa and/or gamma, is 1.4 [/].
Thanks,
Gordan
PS
An HTML calculator dealing with physical properties for air and some other basis species is attached -- physical properties are a function of temperature (only for the purpose of entropy and Gibbs free energy calculations, temperature and pressure are input values, otherwise just the temperature value is the input value)!
Thanks,
Gordan
PS
