Oil Contents In Ammonia
#1 umairbhatti42
umairbhatti42
Posted 13 May 2020 - 01:36 PM
The ammonia received from our supplier contains high contents of oil. This ammonia is first unloaded in a storage facility and is then transferred to our other facility. To remove oil, mostly liquid-liquid coalescers are used. Can anyone provide reference of such facilities where this system is used. How can i simulate  or find number of coalescers to reduce oil contents from 20000 ppm to 10 ppm.
Also, are there any other proven solutions to this problem.
  • 6,715 posts
Posted 14 May 2020 - 01:40 AM
May be trivial , why do you accept this material from your supplier ? he should be responsible to supply the right material , at least to take it back if out of spec !
You should consider an other source .
To add to my comments above a link to Pall you may consider .
https://www.pall.com...ated/HCP-26.pdf
my view
Edited by breizh, 14 May 2020 - 10:08 PM.
