Temp. Rise In Centrifugal Pump
centrifugal pump
9 replies to this topic
#1 raj shekhar
raj shekhar
  • 40 posts
Posted 19 May 2020 - 04:56 PM
Hi Cheresources team,
I hope you all the doing well.
I want to calculate the the temp. rise in centrifugal pump when the pump is dead headed. I got the formula from the below link -
https://powderproces...ature_Rise.html
I used the formula to calculate the temp. rise below is the calculations steps -
Shut off BHP    5 hp
Fluid handled by pump    Ethanol
Fluid density    49.25 lb/ft³
Fluid specific heat    0.6 Btu/lb.°F
Boiling point of liquid    172 °F
Pump casing volume    2.5 ft³
Weight of the fluid inside casing    123 lb
Temperature rise    2.9 °F/min
Temp. rise per min is around 3 deg F, it seems quite high. I need your views on this value. Am I missing something here.
Waiting for your valuable suggestions.
Thank you,
Raj Shekhar Ghosh
#2 latexman
  • 1,782 posts
Posted 19 May 2020 - 05:05 PM
In my experience, that seems reasonable.
#3 Chemitofreak
Chemitofreak
  • 292 posts
Posted 20 May 2020 - 01:22 AM
Can we know the reason for calculating the temperature rise?
are you calculating the minimum re-circulation flow or something else?
#4 fallah
  • 5,019 posts
Posted 20 May 2020 - 01:59 AM
Hi Raj,
It's not so high and as latexman mentioned is reasonable...
#5 breizh
  • 6,623 posts
Posted 20 May 2020 - 02:49 AM
Consider the document attached to support your work.
Edited by breizh, 20 May 2020 - 02:49 AM.
#6 raj shekhar
raj shekhar
  • 40 posts
Posted 20 May 2020 - 09:37 AM
The pump is used here for transferring Ethanol, as it's a flammable liquid I wanted to know what is the temp. rise if we dead head the pump for longer time. If the temp. rise is much higher I will go for a minimum re-circulation line.
Thank You,
Raj Shekhar Ghosh
#7 raj shekhar
raj shekhar
  • 40 posts
Posted 20 May 2020 - 09:38 AM
Thank you Latexman sir and Fallah sir for sharing your valuable experience with me.
#8 raj shekhar
raj shekhar
  • 40 posts
Thank you Beizh sir for the document.
#9 Chemitofreak
Chemitofreak
  • 292 posts
Posted 20 May 2020 - 09:56 AM
Thank You,
Raj Shekhar Ghosh
Please note that minimum re-circulation is required for two reason
1) To avoid cavitation related damage. That is what you are interested in
2) For Mechanical stability of a pump a min. flow is required.
I would suggest you to contact the pump vendor for minimum flow rather than you calculating the same..
I would also suggest you put a minimum flow line (with a RO or control valve based on the motor rating) considering the fluid is Ethanol
#10 raj shekhar
raj shekhar
  • 40 posts
Posted 20 May 2020 - 03:49 PM
Thank You,
Raj Shekhar Ghosh
Thank you Chemitofreak, for your suggestion.
