Material Of Construction For Dm Water
Posted 25 August 2020 - 06:05 AM
Posted 25 August 2020 - 06:29 AM
Generally SS should be used. DM water is often called as hungry water as it rarely contains minerals and this will lead to corrosion of CS. This will also lead to degradation of the quality of the water because of corrosion products.
So wherever there is a stagnation of water e.g. storage tank better go for SS or epoxy coating at the inside of the tank.
You need to discuss this with the Materials Engineer, this would be an easy for him.
Posted 25 August 2020 - 06:32 AM
DM is aggressive/corrosive material , CS is not suitable , let you consider SS or Plastic consider .
attached a guide to support your work
https://www.graco.co...mpGuideEN-B.pdf
Good luck ,
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
