Gas Mixing And Separator Backpressure
gas mixing separator oil natural gas
#1 zamakaze
zamakaze
  • 14 posts
Posted 03 September 2020 - 12:19 PM
If in a gas plant, we have HP sep. at 1200 psig and we compress the gas from Inter-Separator at 500 psig to 1150 psig to mix with the HP gas as per the sketch. In case we change the setting of control valve downstream of the compressor to 1175 psig, I assume the compressor will build up pr. Accordingly. But what happens with the HP gas, will it be able to maintain 1175 psig before mixing with compressed gas? Will there be an effect on operating pr. Of HP separator?
  • Attached File  1211.jpg   56.86KB   3 downloads
  • 7,039 posts
Posted 05 September 2020 - 02:18 AM
Can you route the discharge of the HP separator downstream the PCV managing the pressure of the compressor set @1175 PSIg ?
my 2 cents
#3 zamakaze
zamakaze
  • 14 posts
Posted 05 September 2020 - 09:16 PM
thanks @breizh, i thnk that would be better arrangement to mix the gas
do you think having an upset case pcv downstream to flare will effect working of any upstream control valve
sketch attached
#4 dennisomenka77
dennisomenka77
Posted 21 April 2023 - 09:46 AM
I think it is best to take a gas supply line upstream of the PCV for both HP and LP to comingle before a Pressure control.That way the PC at compressor inlet takes proper charge of upstream pressure of both inlet streams.
Edited by dennisomenka77, 21 April 2023 - 09:47 AM.
