Solid contents from a reactor in the plant is being carryover to the condensers of the vacuum system and clogs the tubes of the condensers. To avoid this problem, we are planning to install a strainer or a cyclone separator in the pipeline to collect the solid debris. Which is better? A strainer or a cyclone separator?
Posted 22 September 2020 - 02:48 AM
Posted 29 May 2023 - 10:08 AM
In my opinion cyclone would be a better option.
Because if we install strainer and solids cover a surface of strainer then it will restrict the flow in pipeline and due that back pressure will develop and there are chances of vaccum break in column.
Posted 29 May 2023 - 02:22 PM
Is there foaming issues?
Is the load fill in RX too high? I.e., not enough disengaging space?
If so, fix these issues first.
Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
Using Different Types Of Prvs To Protect The Same SystemStarted by Guest_FarrahC_* , 09 Dec 2024 |
Purging Blowdown SystemStarted by Guest_Ade24_* , 29 Nov 2024 |
