Binary Interaction Parameters
#1 iOM
iOM
  • 8 posts
Posted 15 November 2020 - 04:18 PM
Good day gentlemen,
Currently I’m working on an excel sheet that uses Ping-Robinson EoS to calculate Z factor. The difficulty I’m encountering is that i couldn’t be able to calculate the interaction parameters, instead i had to take them directly from Aspen Hysys. However, i’d like to know how these parameters have been calculated?
Thanks in advance.
  • 6,715 posts
Posted 15 November 2020 - 08:50 PM
Let you try to get a copy of : The Properties of Gases and Liquids, Fifth Edition Bruce E. Poling, John
M. Prausnitz, John P. O’Connell.
another resource attached .page 9
Edited by breizh, 30 December 2020 - 07:05 PM.
#3 PaoloPemi
PaoloPemi
  • 550 posts
Posted 16 November 2020 - 12:09 PM
BIPs or Binary Interaction Parameters are calculated from experimental VLE / LLE / SLE etc. data,
good sources are DDB (Dortmund Data Bank), Dechema etc.
to calculate these values you need a data regression utility,
the free version of Prode Properties (see prode.com) allows to calculate these parameters (from vapor-liquid liquid-liquid and solid-liquid points) for many thermodynamic models including for example Peng-Robinson, Soave-Redlick-Kwong, Lee-Keesler-Plocker, Benedict-Webb-Rubin and several others including many variants...
Note that many values are also distributed within Dechema and similar sources...
Edited by PaoloPemi, 16 November 2020 - 12:11 PM.
#4 iOM
iOM
  • 8 posts
Posted 16 November 2020 - 03:20 PM
Thanks a lot for the valuable inputs
#5 breizh
  • 6,715 posts
Posted 17 November 2020 - 12:26 AM
In addition to my reply , consider the resource attached :
https://cheguide.com/estimate_BIP.html
Hope this is helping you and others.
#6 breizh
  • 6,715 posts
Posted 30 December 2020 - 07:04 PM
Attached the excel sheet .
