Is the Flow Tubing Head Pressure (FTHP) downstream or upstream of the well head choke valve?
What is the pressure downstream of the well head choke valve called?
Posted 31 January 2021 - 12:33 AM
Posted 31 January 2021 - 12:14 PM
FTHP is upstream the choke. I do not think the pressure downstream the choke has a name however I am certain that its value is lower than FTHP due to the pressure section breaks.
Posted 03 December 2023 - 12:49 AM
Is the Flow Tubing Head Pressure (FTHP) downstream or upstream of the well head choke valve?What is the pressure downstream of the well head choke valve called?
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
