rookie question...what does turn down of 60% for a plant mean...does it mean that it can run at 60 per cent of maximum capacity of 40 per cent of maximum capacity?
Turndown % Meaning
Started by james.corrobro@gmail.com, Apr 03 2021 07:08 PM
turndown ratio turn down
Posted 03 April 2021 - 07:08 PM
Posted 03 April 2021 - 07:39 PM
40% of capacity.
Posted 03 April 2021 - 10:39 PM
"of" is the key.
Posted 03 April 2021 - 10:59 PM
Turndown percent of 60% means the plant can be run within the range of the maximum capacity and 60% of the maximum capacity...
Foe such turndown percent, the turndown ratio will be 100/60=1.66
Gas Processing Unit At Low TurndownStarted by Guest_hira488_* , 14 Oct 2022 |
Oil And Gas Elevated Flare TurndownStarted by Guest_Becchis_* , 19 May 2021 |
Turndown Of A Three Phase Separator - Level SettingsStarted by Guest_zamakaze_* , 20 Jan 2021 |
Path Meaning In Indirect Bath HeaterStarted by Guest_pinakini_* , 31 Aug 2019 |
![]() Meaning Of Pipe Class And Pipe RatingStarted by Guest_inkar_* , 27 Oct 2018 |
