Flow from tank formulas.pdf 184.9KB
818 downloadsConsider a storage tank with open discharge.
Most tank draining calculations use an orifice formula with Cd from 0.6 to 0.98 depending on whether the hole is considered to be a sharp-edged orifice up to a stubby pipe (e.g., tank nozzle).
But if the discharge is through a lengthy pipe or through a valve I would think you would use the Darcy equation for pressure drop due to friction with the driving pressure drop being the difference in head from the top of the liquid in the tank to the point where the pipe discharges.
Here's my quandry. I get a much higher flow result using the Darcy equation rather than the orifice equation. I think the Equivalent Length in the Darcy equation needs to incorporate the entrace effect into the pipe such that if the pipe length is zero there is sufficient equivalent length so the result will equal the orifice calculation (same diameters of course). But the K value for entrance pipes is nowhere near high enough to accomplish this.
I must be missing some fundamental here, or my equations have an error, but the same problem exists if I assume a valve is connected to the tank outlet and I simply use the valve flow coefficient to estimate the flow rate.
Any ideas why I have this discrepancy? I've attached my formulas.
Edited by Steve Hall, 23 April 2021 - 07:14 AM.
