Design Of A Shell & Tube Condenser For Undergraduate Project
heat exchanger shell & tube
#1 DavidSJO
DavidSJO
Posted 09 May 2021 - 06:04 PM
I have been currently tasked with designing a total overhead condenser for a methanol distillation column. In the condenser, for simplicity reason, have I said that a pure vapour methanol product enters the condenser. From the sources, I have concluded that the best action would be a shell and tube, which is horizontal, and the condensation takes place on the shell side. From this, I will also have cooling water running through the tube side. From the literature studied, I cannot find an equipment sizing procedure to work out the overall heat coefficient, which is then used to work out the transfer heat area for the heat exchanger stated, so I wondered if anyone has any guidance or references that can help me through it. I have access to simulation on ChemCAD in where I can obtain any physical properties.
I would use `Engineering Sciences Data Unit Design Guide, ESDU 84023`, but I don't have access to it, neither does my university, which is proposed in Coulson and Richardson.
Heat Exchanger Type: Shell and Tube
Orientation: Horizontal
Condensation occurs in the Shell Side
Totally condensed
Hot stream: Pure Methanol
Cold Stream Cooling Water
David.S.J
  • 6,715 posts
Posted 09 May 2021 - 07:10 PM
On-Line Heat Exchanger Sizing (freecalc.com)
Give a try !
#3 horatorres
horatorres
  • 88 posts
Posted 09 May 2021 - 08:09 PM
hello
Hereafter you will find the link to download the Book Process Heat Transfer from Donald Kern.. This book was the one in the 80 years, when simulators were a dream, we use to design HE.. You will find all than you need do your assignment.  Check you will calculate a condenser; it has a chapter for it.
https://www.academia..._Donald_Q_Kern_
Horacio
#4 breizh
  • 6,715 posts
Posted 09 May 2021 - 10:20 PM   Best Answer
Definitely the reference "process heat transfer " by D.Kern is a very good choice to learn about the principles and the details of mechanisms.
To me there is another good book with examples and excel sheets Engineers should consider :
Heat transfer in process engineering by Eduardo Cao
#5 Chemitofreak
Chemitofreak
  • 292 posts
Posted 10 May 2021 - 01:58 PM
1) Process Heat Transfer: DQ Kern
2) Ludwig's Applied Process Design for Chemical and Petrochemical Plants
These are the two books I would recommend
#6 breizh
  • 6,715 posts
Posted 11 May 2021 - 01:40 AM
Consider to read the doc attached  related to vacuum condenser .
