Recirculation Jet Nozzle(Eductor) Design
storage tank mixing jet nozzle eductor
8 replies to this topic
#1 chanchalg
chanchalg
  • 7 posts
Posted 07 June 2021 - 12:40 AM
Hello Everyone,
I am asked to develop the design of multiple eductors for a storage tank of 35m Dia and 15m Height to ensure the proper mixing of fluid. Only available data is inflow and outflow rates on tank i.e. 1160m3/hr and 2000m3/hr respectively and Nozzle size feeding the ring is of 12NB size.
I was going through previous reports and have found that there is and inner and outer ring of eductors is deployed which is feeded through recirculation pump. I didn't got any design basis and calculation for the same.
I have some very basic queries as listed below:
1. how to decide the number of eductors in outer and inner ring?
2. how to decide required flow rate and pressure to ensure proper mixing of product?
3. how to fix inclination angle of eductors nozzles?
4. how to decide the exit nozzle size of eductor?
5. how to calculate mixing time?
For resolving above queries if you can provide any suitable reference or guidance, that will be a great help of me. Waiting for your valuable response!
Thank You!
  • 6,715 posts
Posted 07 June 2021 - 03:41 AM
Did you try your favorite search engine , key words :  mixing eductor design
https://www.spray.co...ng_eductors.pdf
https://www.s-k.com/...ng-eductors.cfm
good luck
#3 Bobby Strain
Posted 07 June 2021 - 02:46 PM
This doesn't sound like a student query.
#4 chanchalg
chanchalg
  • 7 posts
Posted 10 June 2021 - 06:43 AM
good luck
#5 chanchalg
chanchalg
  • 7 posts
Posted 10 June 2021 - 06:46 AM
Hi briezh!
Thanks for reply!
Actually I have already gone through the suggested documents but I couldn't get more details regarding decision of inclination angle, pump pressure etc. If you can tell something related to the same that'll be really helpful!
#6 latexman
  • 1,812 posts
Posted 10 June 2021 - 07:05 AM
Inclination angle - no specific advice, but in general one usually does not want the liquid jets to break through the liquid surface.
Pump pressure - once the eductor system is pretty much finalised, do a hydraulic analysis of the system.  The pump pressure needed is the back pressure created at the pump's discharge flange by it's entire pipe, fitting and eductor system.
#7 breizh
  • 6,715 posts
Posted 10 June 2021 - 07:28 AM
hi,
I asked our friend : https://www.spray.co...ng_eductors.pdf
you need to dig into the document (link attached)  and use your common sense .
note : prepare a requisition (detail of the tank)  , contact vendors (give them a call or drop them an email )
Hope this is helping you
#8 chanchalg
chanchalg
  • 7 posts
Posted 11 June 2021 - 06:16 AM
hi,
#9 chanchalg
chanchalg
  • 7 posts
Posted 11 June 2021 - 06:17 AM
Hi Briezh,
Thank you very much for your effort. I'm trying to understand the document. This is really helpful.
Chanchal
