Relief Valve Interlocking
prv psv piping interlock
14 replies to this topic
#1 Lapeche
Lapeche
  • 11 posts
Posted 23 June 2021 - 03:39 PM
Hello everyone,
I am looking for articles with feedback/return-on-experience regarding relief valves interlocking:
- focusing on interlocks with key versus 3way valves, example here attached;
- advantages and inconveniences;
- reliability matters ;
- cost.
What readings would you recommend to me, please?
Thank you
#2 Bobby Strain
Posted 23 June 2021 - 04:32 PM
Much depends upon the jurisdiction that regulates such things.
#3 fallah
  • 5,019 posts
Posted 24 June 2021 - 02:02 AM
Hello everyone,
- cost.
API 520 Part II
#4 breizh
  • 6,715 posts
Posted 24 June 2021 - 03:29 AM
In the link attached you will find references to read : http://orangetech.co..._Protection.pdf
At the end it should be a decision from the owner and the management team . Cost should not be the issue .
My view
#5 Lapeche
Lapeche
  • 11 posts
Posted 25 June 2021 - 10:41 PM
Thank you for your replies.
Yes, I do know and use Standards such as API, ASME, and ISO.
I was aiming to collect a return of experience that would help to prove one option versus the other.
I have always used designs with interlocks on staggered relief valves, without any special operational issues. But when using 3-way valves, I already had one of these mechanically blocked, and therefore, impossible to make the relief valve change over, without shutting down the entire refinery steam main header.
#6 breizh
  • 6,715 posts
Posted 25 June 2021 - 11:10 PM
To me the answer is in your reply.
Review with your management team .
#7 fallah
  • 5,019 posts
Posted 25 June 2021 - 11:30 PM
Please provide a brief description for: "Interlock on staggered PSVs" you have already used...
About the mechanically blockage of 3-way valve, have you periodically inspect it for ease and smooth operation?
#8 Lapeche
Lapeche
  • 11 posts
Posted 01 July 2021 - 02:54 PM
Thank you for your message Fallah,
This is the "piping arrangement" I am referring to, as an example:
Unfortunately, I am afraid that no one is taking care of "smoothing" instruments.
#9 Lapeche
Lapeche
  • 11 posts
Posted 01 July 2021 - 02:58 PM
Thank you Breizh,
sure it is, but with stubborn people, we often need a few more arguments.
I am going trough a few references on instrument reliability, I will let you know if something comes up.
#10 Bobby Strain
Posted 01 July 2021 - 03:55 PM
I don't understand what issues you are trying to address. An explanation will be of great help. You might also tell us your facility location.
#11 Lapeche
Lapeche
  • 11 posts
Posted 02 July 2021 - 03:04 PM
Bobby hello,
thank you for your message.
I am searching for references about instruments reliability, more precisely, about isolation valves used on relief valve change over.
The plant is in Europe, if it helps.
#12 Bobby Strain
Posted 02 July 2021 - 04:30 PM
Before you go too far, you should determine what the relevant codes require. Do you have a preference that is hard to sell to your management? Or boss?
#13 fallah
  • 5,019 posts
Posted 02 July 2021 - 10:42 PM
Interlock is applied on Duty/Spare PSVs not on the Staggered PSVs in which following to relief load increment they will be opened one by one till all opened at maximum relief load...
#14 breizh
  • 6,715 posts
Posted 10 July 2021 - 01:01 AM
Consider this reference where the author addresses  the use of a 3 way valve  (chapter 6)
The safety relief valve handbook  by Marc HELLEMANS
Hope this is going to help you
#15 Lapeche
Lapeche
  • 11 posts
Posted 14 July 2021 - 02:46 PM
Thank you again for the reference Breizh
