How to convert PPMw (by weight) to PPMv(Volume) for H2S & moisture(H2O) in gas mixture?
Posted 15 July 2021 - 08:23 AM
Posted 15 July 2021 - 02:05 PM
What assumptions or model or such do you want to use for the conversion?
It seems that, for gas phase calculations, a common assumption is to assume ideal gas. If we do this, then it is a simple matter to convert mass to moles (using the molecular weight), then use the ideal gas law to convert moles to volumes, then total it all up and compute the volume fractions.
Does that sound like an appropriate approach for what you are doing?
![]() Achieving Ultra-Low Water Content (<0.1 Ppmv) For Pipeline PiggingStarted by Guest_Finchh_* , 21 Aug 2024 |
How Do You Convert Ppmv To Ppmmol And Vice VersaStarted by Guest_chemproc_* , 03 Jun 2019 |
Conversion Ppmv Of Moisture Analyzer To PpmwStarted by Guest_Redoctober_* , 28 Aug 2012 |
Ppmv Water In Gas MixtureStarted by Guest_Olaniyi_* , 15 Feb 2012 |
Dew Point And Water PpmvStarted by Guest_Wajid_* , 21 Jun 2010 |
