Temperature Change Of Liquid After Pressure Drop
7 replies to this topic
#1 kangas
kangas
  • 127 posts
Posted 10 August 2021 - 04:47 AM
which law of thermodynamics is associated with the temperature change of a liquid after pressure drop.
For instance, I have a liquid at 50bar and I want to reduce the pressure at 1bar. How I will determine the temperature change?
  • 6,715 posts
Posted 10 August 2021 - 05:52 AM
Consider this resource to support your work
Properties with Variant Fina Pressure – Quest Consultants
Simulators will do the job .
#3 kangas
kangas
  • 127 posts
Posted 10 August 2021 - 08:03 AM
Thanks nice tool.
I would like to better understand the thermodynamics though. I can understand that if you pump something, heat is input. If you expand something energy is released. Does this mean that for every liquid temperature will decrease or are there cases where temperature will increase.
#4 MrShorty
MrShorty
  • 517 posts
Posted 10 August 2021 - 09:23 AM
Are you thinking of something like a Joule-Thompson type experiment/process? I know that the temperature of most liquids will increase when the pressure is dropped along an isenthalp (as in a JT type process).
Thermodynamics is often about processes, which means you may need to know more than just the initial and final states. It may be necessary to explain the process you are using to go from the initial state to the final state.
#5 latexman
  • 1,810 posts
Posted 10 August 2021 - 10:53 AM
From a practical standpoint, for this range of pressure drop the answer is ~ 0 when there is no flashing of vapor at the lower pressure, right?  You could probably debate whether your real world process (CV?)  approaches isenthalpic or adiabatic, but in my experience it is usually closest to isothermal.  Maybe, the temperature goes up 1oC or there abouts, but in my little world that is negligible.  How is this small of a change important to you and your process?
#6 horatorres
horatorres
  • 88 posts
Posted 10 August 2021 - 09:11 PM
This topic is a thermodynamics one...  Here after link to deep it
https://ntrs.nasa.go...19720020315.pdf
for natural gas calculations, there are  extensive papers
horacio
#7 breizh
  • 6,715 posts
Posted 10 August 2021 - 09:22 PM
To answer to your question consider this paper from 1999 published in Chemical engineering magazine :working with fluid that warm upon expansion .
#8 kangas
kangas
  • 127 posts
Posted 13 August 2021 - 02:21 AM
Thanks all for your great help!
