Hi, are there an reliable links or references for finding out relative cost of materials for construction of equipment. Mostly interested in carbon steel vs borosilicate glass but any info on SS 316 or hastelloy is also welcome. I found some references for steel but nothing on glass and relatively how expensive/cheap it is compared to carbon steel. need to know specific costs(cost per weight) for these materials when used to fabricate say an exchanger or a reactor etc at industrial scales
Cost Factor/index Table For Mocs Like Carbon Steel, Glass Etc.
Started by daraj, Aug 29 2021 01:06 AM
![]() Activated Carbon SelectionStarted by Guest_Talhafarooq_* , 25 Nov 2024 |
![]() Colebrook's Equation - Friction FactorStarted by Guest_breizh_* , 10 Nov 2024 |
C Factor For Erosional Velocity For Multi-Phase Flow (Nat Gas/ ProduceStarted by Guest_Sam11_* , 10 Sep 2024 |
![]() Determining The F-Factor Following The Api 2000Started by Guest_Hachimi_* , 06 Sep 2024 |
![]() Environmental Factor "f" Calculation In Psv Fire CaseStarted by Guest_mahmooddalvi09_* , 17 Aug 2024 |
