Pressure Drop Calculation And Allowable Pressure Drop Per Pipeline.
process velocity pressure drop pipeline design internal diameter
#1 Younghun Kim
Younghun Kim
  • 12 posts
Posted 31 August 2021 - 01:35 AM
As per operating company's code, maximum allowable pressure drop per length is limited. (for example 3.5 bar/km)
Wouldn't it be a problem if the pressure required by the demanding process is satisfied?
If the material-related velocity limit(erosion, corrosion, noise) is not exceeded and the pressure of the demanding process is satisfied, is it okay to exceed the pressure drop standard?
Edited by Younghun Kim, 31 August 2021 - 04:30 AM.
  • 6,715 posts
Posted 31 August 2021 - 02:51 AM   Best Answer
If this is a client's requirement you need to follow it .It's the one who pays the bill .
Note : a standard is just a standard not a contract.
my view.
