Edited by lnbsak, 06 September 2021 - 04:40 PM.
Plug Flow Reactor Detailed Cooling Jacket Design
Posted 06 September 2021 - 04:38 PM
Posted 07 September 2021 - 08:05 AM
There is a good article at Cheresources here: http://www.cheresour...d-vessel-design
Consider using internal coils for better heat transfer if possible.
Posted 07 September 2021 - 04:52 PM
Thank you sir for sharing such a great article.
From one old reference (attached below), I got the approximate reactor configuration. Which indicated the reactor tubes are cooled with counter-current cooling oil or BFW
I have also confirmed with a few of my industrial sources that it is the case.
Thank you again.
Posted 07 September 2021 - 07:59 PM
Consider this resource from Internet , you may find pointers to support your work:
http://repository.um...AND_CONTROL.pdf
Posted 07 September 2021 - 08:55 PM
Thank you so much for helping out.
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
