One Air Cooler Instead Of Two
start up the tower air cooler
#1 Movers
Movers
  • 67 posts
Posted 30 September 2021 - 02:01 AM
Hello All.
In attachment I placed sketch with current situation and proposed redesign.
In normal case there is no flow through EA-1. This cooler is used periodically in order to bypass tower when it is shut down. In EA-1 liquid is cooled and in EA-2 vapour are cooled and condensed. Duty is 1 and 9 MW respectively.
I would like to remove EA-1 and use only EA-2 in both cases: 1) normal operation and 2) bypass of the tower.
My concern is if new solution will allow to on-line switch between Case 2 and 1 (start up of the tower). I think that when valves V1-V5 will be properly managed it could be possible. When Case 2 will be operated can only a part of EA-2 (one bundle) be in use? Can you provide me your opinion about this issue?
Kindly Regards
Edited by Movers, 30 September 2021 - 04:07 AM.
  • 6,714 posts
Posted 30 September 2021 - 04:51 AM
This means no spare equipment , right? talk to the operation team .
my 2 cents
#3 horatorres
horatorres
  • 88 posts
Posted 30 September 2021 - 12:56 PM
It is normal, when you have a HX to start up, means that this is an important equipment for shutdown procedure.
As breizh said, look the startup and shutdown procedure and ask for the operator's approval.
Horacio
#4 Movers
Movers
  • 67 posts
Posted 30 September 2021 - 11:50 PM
Thank you
