Hello, everyone!
I am currently an undergraduate student who is doing a plant design project. Can I know whether I can use shortcut method (FUG) for an azeotropic distillation? If not, what method should I use to calculate the reflux ratio, number of stages and feed location manually?
Azeotropic Distillation
Started by Liying, Dec 05 2021 12:37 PM
Posted 05 December 2021 - 12:37 PM
Posted 09 December 2021 - 10:07 PM
ki
search in the web, the acetone water azeotropic distillation. It a plenty examples how to do it.
Horacio
Posted 17 December 2021 - 12:08 AM
Hi Liying,
Consider the links underneath to support your studies.
https://escholarship...96n0xv#page-489
http://www.separatio...om/Mainmenu.htm
Good Luck
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
Aspen V11 Help On Radfrac Distillation Column ErrorStarted by Guest_savinedanglokta_* , 13 Nov 2024 |
![]() How Is The Performance Of The Distillation Tray Calculated? The DistanStarted by Guest_Ahmedforup_* , 11 Oct 2024 |
