Pingpong, for energy/ower balance, often we need to know efficiency values for steam turbine(that drive compressors) aswell as efficiency of compressors themselves(such as syngas compressor). do you know if 70% for steam turbine and 75% for compressor overall is conservative enough? vendors claim higher efficiencies(like 80% for compressors)but i have heard that those numbers are not real. My duty values are within 20MW for these equipment.
Efficiency of centrifugal compressors and steam turbines depend very much on the actual volumetric flowrate through them. The higher the volumetric flowrate, the higher the efficiency.
Note also that there is a difference between polytropic efficiency and adiabatic (isentropic) efficiency for centrifugal compressors. Some sources quote polytropic, others quote adiabatic, and others just quote efficiency without indicating which type is meant.
Moreover there are mechanical losses to be taken into account in calculating compressor or turbine powers, so if a compressor vendor quotes 80 % polytropic efficiency then it will actually be several percent points less after taking all other losses into account.
To answer your question, I would say that a polytropic efficiency of 75 % is conservative enough for a 20 MW centrifugal compressor,
and a 70 % isentropic efficiency is conservative enough for a 20 MW steam turbine.
Attached are some centrifugal compressor data from old Elliott brochures.
Note impact of intake volume on polytropic efficiency. Cfm = cubic feet per minute.
Elliot compressor efficiency.jpg 192.06KB
6 downloads
