Water Entropy Estimation
entropy and enthalpy of water
#1 ahmedi
ahmedi
Posted 19 December 2021 - 04:53 AM
I have a question. The standard molar entropy of subcooled/compressed water (25oC, 1 ATM) is given as 70 J/mol. K. When it is converted to J/gm K the value comes about 3.88 J/kg K. But when we look at the steam tables the value of saturated liquid water entropy is given (25 C, 3.6 kPa) as 0.367 J/kg. K. I could not figure out why there is so much of a difference? As we know, entropy is not a strong function of pressure at a given temperature. Could someone kindly throw light on it please?
S_o (25 C, 101.32 kPa) = 3.88 kJ/kg.K
S_sat (25 C, 3.6 kPa) = 0.367 kJ/kg K
#2 latexman
  • 1,810 posts
Posted 19 December 2021 - 07:02 AM
Are these two values from two different steam tables?  They may use different reference conditions.
#3 Said Salim
Said Salim
  • 98 posts
Posted 20 December 2021 - 02:28 PM
You may check the reference temperatures in both sources.As far as I know the triple point is the reference in IAPWS-97.
You check what is the reference temperature when calculating specific standard entropy to get the value of 3.88 kJ/kg.K
Edited by Said Salim, 20 December 2021 - 02:31 PM.
#4 breizh
  • 6,715 posts
Posted 20 December 2021 - 11:52 PM
Consider this link to support your work (calculators )
https://www.spiraxsa...nd-design-tools
