Demister Pad Design
#1 jprocess
jprocess
  • 316 posts
Posted 05 November 2006 - 05:54 AM
I need information regarding demister pad design for flash separators including the number that reqired,the thickness and etc.
Thanks in advance.
#2 Sandeep01
Sandeep01
  • 12 posts
Posted 06 November 2006 - 03:37 AM
Typically the thickness would vary from 100 to 200 mm, but each case has to be looked into individually with due regard to the service and impact of liquid carryover on the cownstream system, among other considerations. Along with thickness, other parameters like mesh density, permissible pressure drop, etc also need to be specified. You may notice some variation in the specs (for comparable service) from one engineering consultancy to another, as these are developed based on company experience.
A second option, of course, is to go to potential vendors.
Sandeep
#3 Technocrat
Technocrat
  • 81 posts
Posted 13 December 2006 - 03:49 AM
dear jprocess,
once again, for more information on mist eliminators and coalescers and help from the vendors please visit www.koch-ottoyork.com.
DEMISTER is a registered trademark of KOCH OTTO YORK and should not be used freely. instead you should call it wire mesh type mist eliminator.
regards.
