Level Measurement
#1 Kumuda
Kumuda
Posted 14 January 2022 - 03:41 AM
There is a storage tank(11S02) from which we pump fluid into the reactor. There's another big storage tank(11S01) from which the reactant comes into 11S02.If I want to automate the process of the filling of 11S02 using 11S01, what are the equipment that I have to use?
I'm thinking of putting a differential pressure transmitter in 11S02. Kindly suggest your ideas. Thanks in advance
  • 6,715 posts
Posted 14 January 2022 - 05:07 AM
Can you supply a sketch or simple PFD for us to understand ?
#3 latexman
  • 1,809 posts
Posted 14 January 2022 - 08:43 AM
And, is 11SO2 a day tank (continuous process) or a batch tank (batch/semi-batch process)?
#4 breizh
  • 6,715 posts
Posted 15 January 2022 - 12:34 AM
Still waiting for your sketch .
Do you need a continuous measurement ? if yes you can add alarm to it .   Normally you need to install safety guards to prevent overfill of the tank and cavitation of the pump feeding your reactor .
LT could be any technology , just a matter of cost . I like to use radar technology for storage tank , DP is fine.
LSL and LSH could be forks (vibrating level switch) to actuate pump and On/Off valve .
Consider the document attached for better understanding .
Hope this is helping you .
