Hello All,
I am currently filling out process data sheet for gas electric heater. I am little bit confused about determining the governor cases based on the min. / max. Mass flowrate or volumetric flowrate.
I already filled the datasheet with max. and min. duty cases.
But what is going to be more important to the vendor. Mass flowrate or volumetric flowrate?
Thanks all.
Gas Electric Heater
Started by Mohamed_Mamdouh, Feb 20 2022 03:36 AM
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
![]() Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
Electric HeatersStarted by Guest_panoska_* , 24 Sep 2022 |
Fired Heater Convective ZoneStarted by Guest_k.kospit_* , 23 Feb 2022 |
