Optimization Problem, Minimize Heat Exchanger Area
optimization matlab heat exchangers minimize minimum fmincon
#1 newbieneedshelp
newbieneedshelp
Posted 21 February 2022 - 07:13 AM
I want to solve the following optimization problem from Optimization of Chemical processes:
Attached File  841.PNG   46.2KB   7 downloads
Here is what I have done so far:
- Assume wcp is constant for all streams
- Contraints can be derived from the equations of heat: Q=wcp*dTcold=wcp*dThot=U*A*dTLM
Where dTcold & dThot are the change in temperature of each cold and hot stream in a heat exchanger. And dTLM=(dT1-dT2)/ln(dT1/dT2).
A clearer representation of this can be seen in the following image:
Attached File  hx.png   12.62KB   5 downloads
- With that the objective function is specified as: Atotal = A1+A2+A3
- Some linear equilibrium constraints can be made as follows:
From the heat equation dTcold=dThot, from that I got:
T1+T5=400
-T1+T2+T4=400
-T2+T3=100
-The inequality linear constraints can be set as:
T1<T2
T2<T3
T1<T4
-Lower and upper bounds for the variables are somewhat irrelevant, given the constraints, either way I specified them as:
0<A1,2,3<Inf
100<T1<300
100<T2<400
100<T3<600
100<T4<400
100<T5<300
-Lastly, some non-linear constraints were specified as:
U*A*dTLM-wcp*dTcold=0
Could have used dTcold or dThot, but should be the same if the other contraints hold.
Coded that into Matlab (and I have checked multiple times that everything is coded as described above), but I get very inconsistent results, a slight change in the initial guess of the estimated parameters leads to a different answer every time. Is there something wrong with my approach?
  • 7,027 posts
Posted 21 February 2022 - 09:29 AM   Best Answer
Did you try Excel and solver ?
Your set of equations seems correct .
Initialization step :T1,T2,T3,T4,T5
Calculation step :  Q1 ,Q2,Q3  then  A1 ,A2,A3
Optimization step  Min (A1+A2+A3) by changing T1,T2,T3,T4,T5 with associated constraints .
#3 Bobby Strain
Posted 21 February 2022 - 12:03 PM
You have only two variables. So it's simple enough to use trial and error. Track overall area, then pick the smallest. Best if you use VBA. Better still, code it in VB.NET or C#.
