Wet Gas Compressor
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 12 April 2022 - 04:53 AM
Dear Sir,
I wanted to know how Wet Gas Compressor works and Why It is called as Wet Gas Compressor ?
I wanted to know for both Refinery FCCU AND DCU ?
IS it two stage machine always ? How much is the fouling potential in this ?
Thanks.
Best Regards,
CHEMSTRONG
#2 PaoloPemi
PaoloPemi
  • 550 posts
Posted 12 April 2022 - 08:49 AM
wet gas includes a liquid fraction which (depending from amount) can generate problems with std. centrifugal compressors (you should discuss these applications with manufacturers), there are many applications for centrifugal compressors, screws etc.
(as general rule) the performance of a centrifugal compressor under wet gas conditions decreases,  several method have been proposed  for evaluating performance
https://oaktrust.lib...3233/t34-12.pdf
also, wet gas compression stages are not easy to simulate due to difficult to extrapolate the usual parameters to wet gas conditions, I solve these problems (wet gas compression stages) as polytropic stages (the same as for dry gas compression stages) with the unit operation available in Prode Properties (you need a tool able to solve a polytropic stage including phase equilibria).
Edited by PaoloPemi, 12 April 2022 - 09:03 AM.
#3 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 13 April 2022 - 01:20 AM
Dear Sir,
Thanks for your advice.
What kind of liquid components it has basically ?
Why wet gas is fed to compressor ? IS WGC same as Ethylene CGC ?
CHEMSTRONG
#4 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 13 April 2022 - 01:22 AM
How to prevent and Mitigate Fouling in WGC of FCCU and DCU?
#5 PaoloPemi
PaoloPemi
  • 550 posts
Posted 13 April 2022 - 03:51 AM
as said wet gas includes a liquid fraction,
in some applications a liquid fraction is injected at compressor's inlet, there are several benefits, for a short introduction to these applications see
https://www.klmtechg...-Compressor.pdf
for the other questions I would suggest that you contact the manufacturer,
an expert's advice is required.
