Mateo_1974:
We don’t know what gas or gas mixture you are feeding your adsorption unit and what you are removing – or co-adsorbing. I presume you are simply removing water content from a high nitrogen content gas and are doing this prior to feeding a cryogenic separation tower that separates out the nitrogen by fractionation. We also don’t know the physical design of your adsorbers: are the 3 vessels regenerated with a dry regen gas at a minimum of 500 ºF? Is the moist feed gas fed in a downward flow and the regen gas in an upward flow? Are the regenerated beds cooled with the same dry regen gas?
How are the Mol Sieve beds supported? Do you use support grids, like the attached Johnson literature? Or do you use ceramic balls? I assume each vessel has one randomly packed bed of Mol Sieve and no separated sections. What are the Mol Sieve particles? Spheres, pellets, granules? What is the measured pressure drop across each bed at startup, mid-running time, and at the end of each drying cycle?
I agree that any possible channeling during regeneration might be more harmful because it would lead to possible subsequent break-through when the regenerated beds would be put into adsorption. However, it might be more difficult to monitor pressure drop during regen due the relative lower flow rates and superficial velocity.
Basically, there are a lot of parameters that can affect a deficient adsorption cycle and ultimate break through of moisture in the product gas stream. And to make matters worse, there is no absolute or special way to identify, measure, and much less monitor any channeling taking place. In all my years of operating, designing, and building adsorption units in the field I was only able to use logic and what I considered to be the best practices in the art. During the 1960s and 70s we only had basic information on applying Mol Sieves. In converting some of the compressed gas plants under my charge I used both Mol Sieves and Activated Alumina. I used 20 ft/min as my design superficial adsorption velocity and a minimum of 500 ºF for regen gas when drying for cryogenic downstream operations. I always used cryogenic waste gas for regen. With this basic design I easily achieved -90 to -100 ºF dew points – the max at that time that could be measured. I always used metal grids to support my beds and tried my best to measure the packed bed central zone(s) for temperature readings. I used the Ergun equation to figure my bed pressure drops and always used hold drown devices and downflows to minimize bed lift and movement. In all the dryers I operated and built I never obtained any dusting, break throughs, or suspicions of channeling. I never dropped or changed out any adsorbent before 5 years of service on a 7 day/24-hr operation routine.
I don’t understand your explanation of how you operate your adsorbers so it’s difficult to comment on how I would find out if there is any issue to worry about concerning channeling. In my experience I would not give the potential for channeling around the beds any importance unless I had the actual process calculations and the detailed fabrication drawings of the designers and fabricators. Without knowing their parameters and what they designed for, I could not arrive on what to expect as limits or potential issues with your system and its operation(s). With today’s improved and sophisticated field instrumentation it is much simpler and easier to analyze and trouble shoot a process operation. Basically, if you are capable of measuring and monitoring the regen temperatures within the central core of your adsorption beds in the bottom, central, and top sections you should be all right in being able to identify that you are OK with your beds being in good, regenerated shape and safe from any subsequent break through. Locating thermometers at suspected channeling sites and confirming their readings compare with core readings will prove if channeling occurs. I would certainly trust and abide by that kind of empirical field data rather than relying on a computer program based on theory, unknown experimental data or algorithms. Until someone invents a trustworthy channeling flowmeter, I wouldn’t rely on anything else. To the degree that you can safely and thoroughly regenerate all of your adsorbent beds, you will always be able to expect designed performance from them. And the most basic and trustworthy information to ensure that, is from your strategically located regen temperature indicators.
I sincerely hope my experience and comments may give you some ideas or helpful confidence in your operations and that you are able to overcome this issue.
Johnson Support Grids 01.pdf 421.08KB
77 downloads
