Circulation Rate In Refrigerated Storage Tanks
Posted 20 June 2022 - 02:16 PM
Generally, refrigerated storage tanks (e.g. LPG tanks) are equipped with circulation pumps to keep uniform temperature of the tank content.
Is there any guideline or rule of thumb to what the circulation flow rate shaĺl be?
Appreciate your feedback and support...
Posted 20 June 2022 - 02:38 PM
I never used a circulating pump for such storage. Vapor generated from heat input is condensed and returned to the tank. So, where have you encountered a circulating pump?
Posted 20 June 2022 - 11:52 PM
Posted 21 June 2022 - 08:04 AM
What's the maximum temperature variation target for the tank? Use that variation as the temperature gain you would like to limit the circulating flow to, before it re-enters the vessel. With the insulation spec used on the pipe, the pipe's diameter and length, and some conservative summer time assumptions, you can estimate the minimum recirculation flow.
Posted 21 June 2022 - 06:24 PM
Have you responders used circulating liquid for these storage tanks? I haven't seen the likes in 50 years of practice. A circulating pump and cooler are used for fermenters since they require operating temperature below ambient. Along with an agitator. But all my experience is for products of mostly a pure component.
Edited by Bobby Strain, 21 June 2022 - 06:27 PM.
Posted 21 June 2022 - 07:44 PM
I have similar experience on a storage tank of butadiene (sphere) in Indonesia.
edit : I might be wrong .
https://www.reiproce.../6561-vopak.pdf
my 2 cents
Posted 21 June 2022 - 08:30 PM
Posted 23 June 2022 - 06:17 AM
I have seen this for the LPG Storage Tanks in the middle east (in the GCC region mainly).
Edited by Vegeta, 23 June 2022 - 06:17 AM.
Off Spec Condensate Storage TankStarted by Guest_shekhar dhuri_* , 05 Sep 2013 |
![]() Butadine Storage And HandlingStarted by Guest_engmmostafaa22_* , 08 Feb 2025 |
![]() Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
![]() How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) BeStarted by Guest_tokotof_* , 29 Nov 2024 |
