Limit Switch/position Switch
#1 panoska
panoska
  • 314 posts
Posted 25 July 2022 - 11:33 AM
Could you please explain me the limit switch and position switch with an example?
Thank you in advance!
  • 6,715 posts
Posted 25 July 2022 - 06:19 PM
Reactor  supplied with liquid
LSH  to protect the tank from overflow and cut off the feed
LSL  to prevent cavitation of the pump on low level and stop the pump.
#3 panoska
panoska
  • 314 posts
Posted 26 July 2022 - 03:04 AM
Thanks for the reply! I would like to ask you what is the difference between level switch and level transmitter?
(I will search also myself, but your answer will be appreciated.)
#4 breizh
  • 6,715 posts
Posted 26 July 2022 - 03:21 AM
a Level transmitter delivers a continuous reading on which you can assign alarm thresholds ( LAH, LAL ) , LS switches are different technology , for safety purpose , often hard wired .
In the case of level transmitter , the alarm thresholds are there to help the panel operators (sound alarms ) to inform them about deviations in the process.
LSH is placed at a level higher than LAH ,
LSL is placed at a level lower than LAL.
Edit : Don't be confused with position switches on ON/OFF valves to inform panel operators about valve open or close.
My view.
#5 latexman
  • 1,809 posts
Posted 26 July 2022 - 03:44 AM
It is similar to an on/off light switch compared to a dimmer light switch (rheostat).  One is digital, on/off, and one is continuous, dimmer.
#6 panoska
panoska
  • 314 posts
Posted 26 July 2022 - 10:23 AM
Breiz, exactly that is my confusion.
By asking these questions, more things are clarified.
The position or proximity switch is completely different than level switch or temperature switch.
#7 panoska
panoska
  • 314 posts
Posted 26 July 2022 - 11:03 AM
Thanks latex man for your reply.
