Continuous Stirred Tank Reactors Equation: Unexpected Trend
reactor rate convertion plotting sizing of reactors
#1 Molibdeno
Molibdeno
Posted 06 August 2022 - 04:05 PM
A generic reagent A is considered. The behavior equations of a CSTR is the following:
where tau it is the filling time, cA,0 is the initial concentration of A, and XA and it is the conversion of A we want obtain
From Octave Levenspiel, Chemical Engineering Reaction, John Wiley & Sons, Third Edition, page 95, you can see how the graph 1/-r = f(X) has the shape of a crescent function. I tried to reproduce this graph, using
and that's what I get
My question is: to be able to reproduce the graphic in the text, which formula should I use?
Edited by Molibdeno, 06 August 2022 - 05:45 PM.
  • 1,554 posts
Posted 06 August 2022 - 06:30 PM
Your question as represented seems incomplete. Did you leave out a portion necessary for our understanding? You also supply a picture of a graph with no axes labelled. Which graphic in the text are you trying to reproduce?
#3 Molibdeno
Molibdeno
Posted 06 August 2022 - 06:53 PM
I need to report in a graph the value of 1/-rA  = f(XA) since it is possible to graphically obtain the ratio tau/cA,0 necessary to obtain the desired conversion of A. The graph I need is this:
but what I get using  v1w6iPT.jpg is this:
with tau = 2 and cA,0 = 3.
My reasoning is this: if the behavior equation of the CSTR is  lVO2DDq.jpg, so 1/-r = f(XA) is v1w6iPT.jpg.Of course, there is something wrong if the two graphs are not the same
Edited by Molibdeno, 06 August 2022 - 06:58 PM.
#4 Pilesar
  • 1,554 posts
Posted 06 August 2022 - 10:07 PM
If your horizontal axis shows the fraction of component 'A' converted, how can this value be greater than one?
#5 breizh
  • 6,715 posts
Posted 06 August 2022 - 11:00 PM
Consider these resources to support your work:
http://home.ku.edu.t...2-Chapter_2.pdf
https://ocw.snu.ac.k...s/NOTE/7225.pdf
#6 latexman
  • 1,812 posts
Posted 07 August 2022 - 08:27 PM
You are on the wrong track using the solution of the CSTR to get the line in the graph. The line in the graph comes from the kinetic model/equation.
