Pipeline Material Selction
8 replies to this topic
#1 BabRafiq1
BabRafiq1
  • 11 posts
Posted 06 September 2022 - 07:00 AM
Dear Members,
I'm working on a task of pipeline design for Natural Gas containing 26 mole% CO2 and moisture. I have done line sizing using Aspen Hysys but unable to figure out the piping material as its my 1st experience with this kind of tasks.
I will be very thankful if some one guide me or recommend some literature that could help in selection of proper material.
Thanks..
#2 Bobby Strain
Posted 06 September 2022 - 11:41 AM
You should consult your company metallurgist if this is a real project. You can't trust our recommendations.
#3 panoska
panoska
  • 314 posts
Posted 06 September 2022 - 02:05 PM
Bobby, mechanical engineers are also responsible for the material selection diagrams?
#4 horatorres
horatorres
  • 88 posts
Posted 06 September 2022 - 08:56 PM
Mechanical engineers must select the right pipeline material. If ia a complicated fluid, corrosion engineer must be consult
Horacio
#5 eimonthet
eimonthet
  • 9 posts
Posted 10 September 2022 - 03:18 AM
CS is the material used for the construction of  NG pipelines. Use of grade depends on design pressure.
Provide more details like
(1) H2S content
(2) Design pressure
(3) Design temperature
#6 shvet1
shvet1
  • 476 posts
Posted 07 October 2022 - 12:02 AM
ISO 21457, ISO 17348, ISO 17349 might help
#7 Dacs
Dacs
  • 457 posts
Posted 18 October 2022 - 09:09 AM
This is the way.
Process Engineers (as I assume you are too) are not fully qualified to provide proper recommendation for material selection (I know I can't).
Your task however is to provide the proper information to your material specialist, to cover all the possible operating (and even upset) scenarios.
#8 shvet1
shvet1
  • 476 posts
Posted 20 October 2022 - 01:06 AM
@Dacs
for your info
There are many regions in the world where one does not distinguish between a process engineer and a materials/corrosion engineer. High specialization in not common.
#9 Dacs
Dacs
  • 457 posts
Posted 14 August 2024 - 12:26 AM
I have worked with multiple Fortune 500 engineering firms and the role of Material Specialist and Process Engineers is always separate.
Chemical Engineers are not fully equipped to become Material Specialists. Metallurgical Engineers exist for a reason.
Edited by Dacs, 14 August 2024 - 12:26 AM.
