Dear Sir
Need Help About Design Spec In Radfrac Aspen Plus V11
Posted 11 October 2022 - 01:00 PM
Posted 11 October 2022 - 06:29 PM
There is not enough information provided to know for sure. I suspect the simulation is over specified. If the column converges before the design spec, then adding another spec requires another variable to be free to change.
Posted 11 October 2022 - 10:43 PM
Thank you for your advice sir,I simulate about change ethanol to acetone after RSTOIC the products are acetone, acetaldehyde,CO2,H2,ethylene and excess ethanol and water after reactor the stream deliverd to flash column to separate gas-liquid phase after that deliver to distillation (Radfrac) to separate acetaldehyde the results from RADFRAC column are mass fraction of acetaldehyde is 0.9 and reflux ratio(mole) is 3.05 the final column which i can separate acetone the bottom stram of this column will be the recycle stream to feed preparation for this reason i gonna use design spec for all my radfrac and vary reflux ratio and distillate rate Or i can vary another variable sir Please advice me
Thank you so much sir to reply and recommend
Posted 11 October 2022 - 11:13 PM
Can you draw a sketch of your set up (Process flow diagram) and post it, it will save time for people to understand?
In addition, let you provide information about the steams (Composition, flow, temperature, pressure).
This should help you and others willing to help.
Posted 13 October 2022 - 10:53 PM
Thank you sir for your recommend
Here's the PFD
https://docs.google....dit?usp=sharing
The inlet stream(stream 12) mass fraction ofis
ETHANOL 0.047
Posted 14 October 2022 - 09:18 PM
I was expecting someone knowledgeable about the software to support you, anyway you may be able to increase the number of iterations and/or break the loops performing calculation manually to reach an acceptable solution which could be the initialization point for the automatic calculation after reestablishing the loops.
Sorry I cannot offer more, waiting for others to support.
Sawasdee krub, chokdee .
Posted 15 October 2022 - 06:43 AM
Posted 15 October 2022 - 06:57 AM
Without knowing your specs with their variables, there is not much info to go by. Each spec should match with its own variable. The variable has to have freedom to adjust without violating mass balance constraints. I still suspect the problem is over specified somewhere.
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
