Gas Processing Unit At Low Turndown
gas processing dehydration unit mechanical refrigeration unit hydrocarbon dewpoint control process engineer oil and gas industry low turn down ratio dewpoint control of gas chemical engineer triethylene glycol
No replies to this topic
#1 hira488
hira488
Posted 14 October 2022 - 11:22 PM
Greetings!
I want to know the operational challenges of mechanical refrigeration unit (using propane as a refrigerant) on low turndown ratio. Same for TEG dehydration unit. Gas processing plant is designed at 20MMSCFD capacity @1200psig, due to declining gas pressure and flow around 6MMSCFD @ 780psig, what will be the operational challenges?
Mechanical refrigeration unit has a propane chiller and screw compressor.
