Pipe Line Surge Pressure
#1 Ranga v
Ranga v
  • 23 posts
Posted 12 December 2022 - 08:54 AM
Naphta tranfer line appox  ~ 100 km, 6"  currently pumped at the rate 100 m3/hr needs to increased to 160 m3/hr. How do i check the surge pressure for the increased flow.Naphta density is 670 kg/m3, line pressure 40 kg/cm2g.
#2 latexman
  • 1,812 posts
Posted 12 December 2022 - 09:55 AM
I'm not sure what you mean.  Can you be more descriptive, please.  Surge pressure would be if a valve closes too fast, but you give no valve closing time.  Do you mean the increase in pressure drop due to the increased flow?
#3 Ranga v
Ranga v
  • 23 posts
Posted 12 December 2022 - 10:56 PM
Increase in the pressure.Considering quick valve closure time duration 5 sec.
#4 Bobby Strain
Posted 13 December 2022 - 12:46 PM
You will need a new study with the appropriate software.
#5 shvet1
shvet1
  • 476 posts
Posted 14 December 2022 - 12:49 AM
Rule of thumb see McAllister's Pipeline Rules of Thumb Handbook para. "How to determine the maximum surge pressure in liquid-filled pipeline when a main valve is closed suddenly" (page 386 in my copy).
Companies practices see:
- Japan Gasoline's standard #210-120-1-74E
- Shell's practice #31.38.01.11 para. 2.3.4
- SIGTTO's Guidelines for the Alleviation of Excessive Surge Pressures on ESD for Liquefied Gas Transfer Systems
Calculator see:
- Cheresources.com/Downloads/ChE Plus Subscription Files/Premium Excel Spreadsheets/Water Hammer Pressure Development
https://www.lmnoeng....aterHammer.php
Simulators see dedicated software e.g. Pipenet, Pipephase.
Theory see Streeter&Wylie's Fluid Transients.
For a brief view see:
- KSB's Lexicon chap. "Hydraulic surge"
- file attached
... and references in those. A simulator from a reputable vendor is preferred.
Note that pressure surge depends on speed of sound which depends not only on liquid properties but what material a pipe is made of and even pipe isometric and supports
Edited by shvet1, 16 December 2022 - 02:35 AM.
#6 breizh
  • 6,715 posts
Posted 14 December 2022 - 05:18 AM
take a look:
 https://www.cheresou...pipeline-surge/
#7 Bobby Strain
Posted 14 December 2022 - 12:07 PM
Ranga,
       This is serious business. So you should find an engineer or company who can reliably perform an analysis with accepted procedures. Have a look at this.
       https://www.betamach...hammer-analysis
Edited by Bobby Strain, 14 December 2022 - 12:31 PM.
