Pumping
centrifugal pump naphtha reformate platforming naphtha hydrobon hydrotreating refinery operations pumps operations
#1 engineer24
engineer24
  • 5 posts
Posted 05 January 2023 - 08:17 AM
Hello Guys.
I hope you all are fine and enjoying your life with health wealth and peace.
CASE STUDY
I have a question and I am confused in that. The questions is;
Pump P01 used to pump treated naphtha having RVP of 1.8 psi. Can we use this same pump P01 for pumping reformate (catalytic reforming product) having RVP of 6-9 psi.
Note: We cannot change pump specification as its already rated and in operation.
Pump Details:
Pump No 01 (Feed Pump) (Untreated Naphtha Pump)
Suction = - 1.5 Psig
Capacity = 144 USGPM
Differential Head = 576 psi
Discharge = 574.5 psig
Pump No 02 (Reboiler Pump) (Treated Naphtha Pump)
Suction = 93 Psig
Differential Head = 428 ft
Discharge = 512 psig
Either these both pumps (P01 & P02) will work or not ? These both pumps are used for pumping naphtha. P01 is for untreated naphtha & P02 is for treated naphtha. Now can we use anyone of these pumps for pumping reformate ? Line sizes/dimensions are not changed its same. Instead of pumping naphtha to location we need to pump reformate.
  • 6,715 posts
Posted 05 January 2023 - 08:32 AM
Only you can perform the hydraulic calculation and decide whether or not these pumps are suitable for your application.
You or someone in your organization need to establish a specification sheet and submit it to vendors who supplied your existing pumps for advice.
My view
#3 shvet1
shvet1
  • 476 posts
Posted 09 January 2023 - 12:38 AM
Did you contact seal manufacturer will it withstand increase of RVP?
