Eventhough in both cases liquid flow is not going out.
Where does continuously rotating impeller energy gets converted into?
Kindly guide. Thanks.
Edited by Venkat @89, 20 February 2023 - 10:12 AM.
Posted 20 February 2023 - 10:06 AM
Posted 20 February 2023 - 10:38 AM
Maximum head at zero flow and the energy will go into waste heat/higher stream enthalpy.
Posted 20 February 2023 - 11:26 AM
The centrifugal pump impeller accelerates the liquid to the maximum velocity at the tip/periphery (RPM x radius) of the impeller. The velocity cannot mechanically exceed this value, so it is "capped". The diffuser converts this kinetic energy to potential energy (pressure) as per the Bernouilli equation. Since the kinetic energy is capped, so is the potential energy (pressure).
A PD pump keeps packing liquid into the dischagre piping via mechanical displacement until something breaks or a PRD opens.
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
Esp Or Sro PumpStarted by Guest_sima-f_* , 05 Jan 2025 |
