Can someone help me to understand the how exactly trapped vapor in pipeline can reduce liquid flowrate?
Edited by halkeshhulk, 26 February 2023 - 04:57 AM.
Posted 26 February 2023 - 02:03 AM
Posted 26 February 2023 - 06:07 AM
Trapped gas occupies pipe flow area, increasing liquid velocity and pressure drop, thus reducing liquid flowrate..
Posted 26 February 2023 - 08:51 AM
Thank you for the reply sir.
Can I consider the trap air location as a reducer in the pipeline and pressure loss same as reducer?
In case when the trapped gas quantity increases, can't the gas gets pushed off from the loop to the downstream vessel or column due to high velocity of the liquid?
Posted 26 February 2023 - 10:06 AM
Probably not.
What is the exact problem/situation? How is the air/vapor lock forming? More details = better reply.
Is it a cooling water return header up on a high rack?
Posted 26 February 2023 - 02:42 PM
Probably not.
Posted 26 February 2023 - 04:48 PM
Posted 03 March 2023 - 02:43 AM
As explained by Latexman, the vapor increases the liquid velocity like a reducer but there is another reason for the increase in overall pressure drop. Even if the velocity of the liquid is not enough to flush the liquid out of the pipe it will push the vapor in the direction of flow and this will generally mean that the vapor is partially forced down the down-sloping piping after the high point where the vapor is collecting. Having this static bubble of vapor means that the liquid cannot fill the cross section of the down-sloping piping and there is no (or less) pressure recovery in the liquid as it flows downwards from the high point. So static head is consumed in lifting the liquid to the high point but is not fully recovered on the way down again. This is known as slack flow and google will give you all the details.
In order to flush the vapor with the liquid you need a minimum Froude Number. Typically this is taken to be about 0.65 for "horizontal" pipelines.
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Acumulador De Vapor En Una Planta TextilStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
