Pressurization (Equalizing Line) Across Shutdown Valve
sdv esdv shutdown valve pressurizing line equalizing line
#1 Mohamed_Mamdouh
Mohamed_Mamdouh
  • 12 posts
Posted 05 March 2023 - 03:28 AM
I am looking into methodology to size pressure equalizing line (Pressurizing Line) across shutdown valve ?
Any hints or rule of thumbs that I could use ?
Also if there is an international standard I could use that would be helpful ?
I am thinking I might find a rule of thumb or a common practice table based on the valve size and the delta P ranges across the valve.
Thanks in advance for your help.
M.A.
#2 chocobang
chocobang
  • 63 posts
Posted 05 March 2023 - 04:14 AM
I'm not sure about a standard out there that prescribes pressurisation line (but keen to know if there is one).
Usually DN200 or above, you want a DN50 pressurisation valve to prevent the huge valve from damaging its seal.
Cheers,
Chris
#3 Mohamed_Mamdouh
Mohamed_Mamdouh
  • 12 posts
Posted 05 March 2023 - 04:48 AM
Cheers,
Chris
Do you have any specific criteria for sizing that line ?
#4 latexman
  • 1,809 posts
Posted 05 March 2023 - 08:35 AM
I would use Crane’s Technical Paper No. 410.
#5 Pilesar
  • 1,554 posts
Posted 05 March 2023 - 04:00 PM
Determine the target time to equalize pressure then size the line to meet that time while keeping the line at least large enough so that it won't break if someone climbs on it. Unless the line is so small that it causes annoying delay, then no one will probably care what size you install. If a 2-inch line works, then just spec that and begin on the next task on your list.
#6 chocobang
chocobang
  • 63 posts
Posted 06 March 2023 - 01:45 AM
And watchout for JT effect.
