Set Pressure Of Multiple Psvs
14 replies to this topic
#1 Vegeta
Vegeta
  • 133 posts
Posted 28 March 2023 - 06:31 AM
Team,
I am working on the relief valves of an equipment at which the relief load of the non-fire scenarios is extremely higher than the fire scenario (approximately 100 to 3, respectively).   I'm thinking of providing two relief valves: one for the non-fire scenarios and the other for the fire scenario.   I have the following questions:
1. Is this doable in the context of ASME & API (does this fall under multiple devices installation in API 520?)?
2. If yes, what can be the set pressure values of each PSV?
Your feedback is highly appreciated...
#2 latexman
  • 1,868 posts
Posted 28 March 2023 - 04:23 PM
Why?  If the non-fire scenarios >> fire scenario, just provide a PSV for the worst non-fire scenario and it will easily relieve the fire scenario, right?
#3 Vegeta
Vegeta
  • 133 posts
Posted 28 March 2023 - 06:18 PM
The view has been that the big PSV can relief the pressure in the fire scenario but it is going to re-close extremely fast and the cycle will repeat again (hopefully not quickly). That is the driver of the idea of two PSVs - big and small.
#4 Bobby Strain
Posted 28 March 2023 - 10:55 PM
Forget it. How likely is the equipment to experience a fire when it is blocked in?
#5 snickster
snickster
  • 82 posts
Posted 29 March 2023 - 12:46 AM
If there is a fire who cares if the relif valve chatters.
#6 Vegeta
Vegeta
  • 133 posts
Posted 29 March 2023 - 12:53 AM
For my knowledge,
What if there have been another operational scenario which requires a small capacity as the one for fire?
For example, there are three scnarios such that:
Operational scenario 1: 100%
Operational scenario 2: 3%
Fire scenario: 3%
How many PSVs (in category) shall be there? and how to set their set pressure?
#7 Vegeta
Vegeta
  • 133 posts
Posted 29 March 2023 - 01:12 AM
Very unlikely
#8 latexman
  • 1,868 posts
Posted 29 March 2023 - 05:29 AM
That may make more sense. It depends on the frequency of occurrence of OS2 versus that of OS1? Staged set pressures would be needed to make it work. Do you have enough room above normal operating pressure and below MAWP?
A fire is a rare event.
#9 Vegeta
Vegeta
  • 133 posts
Posted 29 March 2023 - 09:10 AM
The operating pressure is 290 psig and the MAWP is 360 psig
#10 Vegeta
Vegeta
  • 133 posts
Posted 05 April 2023 - 07:28 AM
Dear team,
Any guidance?
#11 latexman
  • 1,868 posts
Posted 05 April 2023 - 07:57 AM
Are all scenarios vapor?
#12 seuenergy
seuenergy
  • 40 posts
Posted 05 April 2023 - 09:44 AM
Hi, Can you give some data about the bigger scenario requires ? for example, 10 inches? or 12 inches?
#13 shvet1
shvet1
  • 476 posts
Posted 07 April 2023 - 05:35 AM
@Vegeta
See quotes here
https://www.eng-tips....cfm?qid=504687
#14 Vegeta
Vegeta
  • 133 posts
Posted 07 April 2023 - 09:02 PM
In fact I posted this topic because I got several PSVs of the same concept.  In general, most of these PSVs have only vapor relief scenarios with few which have both vapor and liquid relief scenarios.
Is the idea behind your question the blowdown of the PSVs?
#15 Vegeta
Vegeta
  • 133 posts
Posted 07 April 2023 - 09:10 PM
In this particular example I picked, the big PSV is 4"P6".
